Manufactured solutions for incompressible Navier-Stokes |
March 24, 2013, 10:56 |
Italo
Rep Power: 16 |
I am testing a solver for the incompressible Navier-Stokes equations using manufactured solutions. The code uses a 1st order projection method on staggered grid, very similar to the MAC method. I use 1st order time stepping and second order spatial derivatives.
If I choose a manufactured solution that is divergence-free, all works fine. I get second order convergence for a stationary problem. But if the manufactured solution is not divergence-free, the method drops to 1st order, even though I added the source term for the Poisson equation. I found some publications that also use divergence-free manufactured solutions, but none explain why. Must the manufactured solution be divergence-free? Isn't it possible to test the code with a more generic solution? It seems intuitive that it should work. When solving the Poisson equation on a square surrounded by Neumann boundary conditions, I must prescribe the pressure at one point. And that is exactly on that point that the error is big. And the error only shows up when using non-divergence-free manufactured solutions. |
March 25, 2013, 10:14 |
#2 | |
Mlohry
Similarly, your numerical method would have to drop to first order if your solution contains discontinuities, so I wouldn't be surprised to see only first order convergence for any such solution. |
March 25, 2013, 10:20 |
Italo
Rep Power: 16 |
The manufactured solution is not a solution for the original NS equations. A source term must be added to the equations so that it becomes a solution.
Display Modes | |
Filtered navier stokes equation..LES:: | Palani Velladurai | Main CFD Forum | 7 | September 6, 2013 03:51 |
ILU for Navier stokes problems | Raju | Main CFD Forum | 5 | July 29, 2006 15:15 |
Navier stokes compresible viscid flow fea, somebody can help? | Jose Choy | Main CFD Forum | 3 | October 24, 2003 03:28 |
Newbie:Viscoelasticity and Navier stokes equation | Rajil Saraswat | Main CFD Forum | 2 | June 9, 2003 08:21 |
help: I am trying to solve Navier Stokes compressible and viscid flow | Jose Choy | Main CFD Forum | 2 | May 18, 2000 06:45 |
