April 27, 2006, 01:17 |
reference about the surface tension
HI:
does sombody know a good reference for the surface tensions! regards |
April 27, 2006, 11:03 |
Re: reference about the surface tension
R. F. Probstein, Physicochemical Hydrodynamics - An Introduction, Wiley Interscience, 1994
Huh. C., Scriven LE. Hydrodynamic model of steady movement of a solid/liquid/fluid contact line. Journal of Colloid and Interface Science. 1971; 35: 85-101 Dussan V., EB., Davis SH. On the motion of a fluid-fluid interface along a solid surface. Journal of Fluid Mechanics. 1974; 65: 71-95 |
April 27, 2006, 20:42 |
hi:
must we give the contact angle during the numerical simulation? regards |
April 28, 2006, 05:32 |
That's the best way to do it. Then you have to decided whether the contact angle is static or dynamic. Static is more stable, but dynamic is more realistic. Depends on your application.
April 30, 2006, 10:52 |
Thank you very much is the contact angle a constant?
May 3, 2006, 05:10 |
That's what we mean by static and dynamic. A static contact angle is constant, but for a moving contact line it is physically unrealistic, although this might not be significant (depending on application). A dynamic contact angle is where theta varies, which is more realistic, but is MUCH more expensive computationally. Factors that can cause changes in contact angle are local velocity vector, surface shape/energy/cleanliness. Concentration, temperature and electric fields are other factors. Enjoy!
May 25, 2006, 18:04 |
What do you exactly mean by computationally expensive? I'm working on pretty much the same stuff and I don't know if the static and dynamic contact angle implementations are very different. As long as you calculate the velocity of the contact line, using a dynamic contact angle model you should be able to evaluate the dynamic contact angle.
Cheers, Shahriar |
Display Modes | |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
OpenFoam 1.6-ext - RPM build errors | preibie | OpenFOAM | 12 | September 8, 2011 03:12 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Compiling new Solver with wmake | lin123 | OpenFOAM | 3 | April 13, 2010 14:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
