-   -   How to identify the faces and set boundary conditions when using code-saturne? (http://www.cfd-online.com/Forums/main/115165-how-identify-faces-set-boundary-conditions-when-using-code-saturne.html)
Hayibada March 25, 2013 11:39
I 'm trying to use code-saturne to simulate the plume of rocket motor nozzle. I use ICEM for meshing. And I found that the faces which were defined as parts in ICEM can not be identified when I import the mesh to code-saturne with CGNS format. So I can't set boundary conditions in code-saturne because I don't know the names of the faces(or the colors which be used as the definition in code-saturne).
Any ideas are welcomed.
Thank you very much,
Durant
