How to identify the faces and set boundary conditions when using code-saturne?
Old   March 25, 2013, 10:39
Default How to identify the faces and set boundary conditions when using code-saturne?
Ran.Duan
Hayibada is on a distinguished road
I 'm trying to use code-saturne to simulate the plume of rocket motor nozzle. I use ICEM for meshing. And I found that the faces which were defined as parts in ICEM can not be identified when I import the mesh to code-saturne with CGNS format. So I can't set boundary conditions in code-saturne because I don't know the names of the faces(or the colors which be used as the definition in code-saturne).
Any ideas are welcomed.
Thank you very much,
Durant
Hayibada is offline   Reply With Quote
code-saturne, icem
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
