May 29, 2006, 09:27 |
spline interpolation
hai ,
I am having certain vertex points of MUR 228 test case (that is turbine cascade,basically a aerofoil ) which i have imported to Gambit then next step is joining this vertex points ,joining them is done by nurb option basically a spline interpolation where it is not mentioned whether it is 3rd order spline interpolation or 5th order , and it was mentioned in jonas paper that 5th order spline interpolation to be used for getting proper results y+ obtained is ok but still the w/m^2 k ie.., surface heat transfer distribution still not coming properly what would be the reason , i am thinking reason would be by default gambit possess a 3rd order interpolation .......... is it i have to try with other option other than the gambit i hope u understood the problem though it is too hippy so i kindly request u to see over this issue regards bajjal |
Display Modes | |
Two dimensional cubic spline interpolation | flappingwing2008 | Main CFD Forum | 5 | December 22, 2016 22:55 |
Surface interpolation schemes and parallelization | jutta | OpenFOAM Running, Solving & CFD | 0 | February 25, 2010 15:32 |
momentum interpolation for collocated grid | Hadian | Main CFD Forum | 4 | December 25, 2009 08:25 |
some references for the spline interpolation | ztdep | Main CFD Forum | 0 | March 11, 2006 11:22 |
3d spline interpolation | Matthias | Main CFD Forum | 6 | January 11, 2002 01:47 |
