spline interpolation
hai ,
I am having certain vertex points of MUR 228 test case (that is turbine cascade,basically a aerofoil ) which i have imported to Gambit then next step is joining this vertex points ,joining them is done by nurb option basically a spline interpolation where it is not mentioned whether it is 3rd order spline interpolation or 5th order , and it was mentioned in jonas paper that 5th order spline interpolation to be used for getting proper results y+ obtained is ok but still the w/m^2 k ie.., surface heat transfer distribution still not coming properly what would be the reason , i am thinking reason would be by default gambit possess a 3rd order interpolation .......... is it i have to try with other option other than the gambit i hope u understood the problem though it is too hippy so i kindly request u to see over this issue regards bajjal |
