-   -   Questions on a pressure profile (http://www.cfd-online.com/Forums/main/115353-questions-pressure-profile.html)
saisanthoshm88 March 28, 2013 17:40
1 Attachment(s)
I have some questions on a pressure profile obtained from a simple 2D laminar pipe flow.
Please look into the attached .jpg image of the pressure contour
Could some one please provide clarifications to the following questions I have -
As the flow proceeds from the inlet, there is a gradual pressure drop. Could this be solely attributed to the frictional losses due to wall shear ?
The bernoullis theorem doesn’t seem to hold good here because it is expected that the pressure should increase as the cross sectional area increases for the flow, however a pressure drop is witnessed from the plot. Could you please explain the limitation of bernoullis theorem in this case
FMDenaro March 28, 2013 18:19
Bernoulli theorem simply does not apply for viscous flow! For laminar pipe flow you have an exact solution, the streamwise pressure gradient is balanced by the tangential stress variation
saisanthoshm88 March 29, 2013 06:03
Thank you very much for your response. I've gone through some books and found that it's a case of Poiseuille flow and I understand that Bernoullis theorem is not applicable here as it is a viscous flow (the flow has a very low reynolds number Re < 1 so the viscous effects clearly dominate the inertia). Yes the pressure drop is due to the viscous shear , the shear stress acts in a direction opposite to the flow and a pressure drop from inlet to outlet is required to counter balance this.
