Presure Field Not Converged in FSI using Ansys-CFX Coupling |
August 5, 2013, 03:57 |
aah
Rep Power: 13 |
Hi Every body
I'm simulating FSI case of interaction between an Airfoil(NACA0012) and air. i first run steady state Fluid only simulation and after use it as initial condition for my FSI problem. in FSI case i also use constant flow of 10[m/s] as in steady case, so i should see no change in pressure and velocity fields, but i see that from first time step although the velocity field keeps the same, but pressure field not solved good and in fact is Funny( i attached my pressure counter) !! for inlet i set velocity(10[m/s]) and for outlet relative static pressure = 0 i have a C-mesh i will thank a lot for Anybody helps me |
Problem in coupling CFX and Ansys for fluid-thermal sim. | Jordi | CFX | 21 | March 1, 2017 05:03 |
2way FSI with Ansys workbench | lingdeer | ANSYS | 3 | May 9, 2013 03:48 |
Ansys + Fluent 2-way FSI coupling | raditz | FLUENT | 2 | February 14, 2013 14:37 |
Restart FSI run on ANSYS CFX | lingdeer | CFX | 3 | October 10, 2011 09:47 |
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! | Cirion0000 | CFX | 0 | July 6, 2009 14:26 |
