Best turbulance model for analysis
Old   March 12, 2013, 01:25
Default Best turbulance model for analysis
adi
addy01 is on a distinguished road
I am doing a undergraduate research for calculating drag force and co-efficient of drag on heavy vehicle. please suggest me best turbulence model which one i should select for more realistic and accurate result. And please tell me should i scale down my model or i should perform analysis on full length model?? nd Wht should be OPTIMUM no of iteration for convergence?? I am using SOLIDWORKS FLOW & AUTODESK CFD.
addy01 is offline   Reply With Quote
Old   March 15, 2013, 15:18
atmcfd's Avatar
ATM
atmcfd is on a distinguished road
Dear Addy,
1) There is no such thing as "best" turbulence model... but usually in these cases k-epsilon / Spalart - Allmaras models are preferred ( and well documented for external flows, so you can refer)
2) Scaling is really your choice, provided a good scaling factor exists for your problem. Else, its safer to do a full length sim. But if you want a good solution and want to observe the trailing vortices etc. from the vehicle, you might have to make the near wall mesh quite fine, and this will increase your computation time.
3) There is no such thing as the optimum no. iterations for convergence in turbulent flow simulations. you can give a reasonably low tolerance criteria for the residuals. The residuals going down is a good indication of convergence,but not the only one. You can also observe the flow statistics , like averaging of the velocity fields etc. and when you get something close to a statistically stationary/uniform field, you can say that the simulation has converged (almost)
atmcfd is offline   Reply With Quote
Old   March 16, 2013, 00:51
Post Thank you sir!!!
adi
One more thing i want to ask if i scale down my model then i have to increase the velocity in same proportion. Sir can u tell me what is the maximum speed till that we can neglect the effect of compressibility?? neglect the Effect of mach number on Coefficient of drag?? Please Reply..
Old   March 16, 2013, 10:47
Lefteris
Aeronautics El. K. is on a distinguished road
You have to adjust the velocity with respect to the characteristic length of your model in order to have the same Reynolds number.
If the flow you're studying is not dominated by viscous effects (which in your case I believe it's not) then you can approximate the flow as incompressible if the Mach number is less than 0.3 (Ma<0.3).
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   March 31, 2013, 14:04
mohammed mahdi
momahadi30 is on a distinguished road
the appropriate turbulent model for aerodynamics application according to Tinoco is K-omega SST with transiltional flow.
momahadi30 is offline   Reply With Quote
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 15:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 20:51
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
