Numerical stability issues
Old   June 5, 2006, 04:03
Default Numerical stability issues
poornima
I am trying to solve a two dimensional heat conduction problem through fully implicit discretization.
I have a problem in getting a solution when I change the delta time. I think courant number poses constraints on the values of the delta time, delta axial, delta radial.
Can someone throw more light on the courant constraints and can send me some useful material on the same.
Thank you. Poornima
Old   June 5, 2006, 19:16
Default Re: Numerical stability issues
khaiching
Hi: Normally, the courant limit comes with the explicit discretization, but not the fully implicit one. Of course, to resolve the transient details, small dt is desirable; however, it may take more time-step to converge to the same result. In some cases, small dt may enhance the numerical stability, in which the same analogy is adopted in the method of "false time step"
-khai ching-
Old   June 7, 2006, 11:04
Dominic Chandar
Yes, Thats very true: When you have an implicit discretization, The courant number does not have much effect on the stability BUT accuracy. It doesnt mean that u can use large courant numbers...When you are, you infact are loosing the accuracy by doing so. Check your boundary conditions again properly. What solver are you using for your implicit solution ? and what kind of problems are you having when u vary dt?
--Dominic
numerical stability HaKu Main CFD Forum 0 June 28, 2011 12:17
Numerical Weather Modelling : Time and space resolution issues chriswatt Main CFD Forum 0 February 15, 2011 21:32
numerical stability due to cross derivatives wen long Main CFD Forum 2 September 12, 2005 02:10
numerical stability analysis Wen Long Main CFD Forum 1 May 22, 2002 00:14
Stability for Nonlinear Numerical Scheme Guo Main CFD Forum 3 February 12, 2001 12:21
