Effect of turbulence of flow on lift and drag coefficients
Old   April 9, 2013, 00:59
Default Effect of turbulence of flow on lift and drag coefficients
M. Abdul Akbar
akku is on a distinguished road
Dear All,
What is the effect of turbulence of flow on the lift and drag coefficients of an aerofoil ?. This is for aerofoil shapes used in vertical axis wind turbine applications (typically in low Reynolds number regime).
Could anyone suggest me a good paper to read on the topic
Thank You
akku is offline   Reply With Quote
Old   April 9, 2013, 01:12
Default Question solved
M. Abdul Akbar
Question solved
Calculate Lift and Drag Coefficients CL and CD sven OpenFOAM 12 May 20, 2020 22:54
lift and drag coefficients around a ground vehicle Pedro CFX 3 September 5, 2012 18:31
Great lift coefficients but negative drag coefficient?! nez FLUENT 0 November 28, 2011 13:57
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 14:45
External Flow Computations - Lift and Drag Ramanath KS Main CFD Forum 9 December 28, 2000 17:38
