April 10, 2013, 09:00 |
system coupling ansys 14 - error
karuppasamy
Hi friends,
While solving the solution for 2-way Fluid Structure Interaction problem with the option SYSTEM COUPLING in ANSYS 14.0 i got an error after completion of the iterations. The error is as follows :- "Update of the solution component in System Coupling failed: Update of the Solution component in System coupling did not mark container as updated (final state is OutOfDate)." Is this problem solvable ? THANK YOU |
May 20, 2014, 21:36 |
from fluent manual
saleh Gharaie
Rep Power: 11 |
In order to have changes made in Fluent systems propagated to downstream System Coupling systems, save your project, synchronize with Workbench, or close Fluent. This will ensure that the information passed to System Coupling matches settings in Fluent. If this is not done, the analysis may be allowed to run but the following Workbench state error will be issued at the end of the run: Update of the Solution component in System Coupling failed: Update as updated (final state is OutOfDate)of the Solution component in System Coupling did not mark container |
ansys 14.0, fsi, fsi mesh, system coupling |
error compiling modified applications | yvyan | OpenFOAM Programming & Development | 21 | March 1, 2016 04:53 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 15:46 |
attach/detach (valve opening/closing) | phsieh2005 | OpenFOAM Running, Solving & CFD | 2 | March 21, 2009 05:18 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
