some questions about SA turbulence model?
Old   June 6, 2006, 04:20
Default some questions about SA turbulence model?
J. Jiang
Dear friends,
Now I'm working on numerical simulation for airfoil stall using DES of SA turbulence model(by finite volume method,LU-SGS scheme,dual-time stepping method).But I haven't done any related work in that field.So I have some questions/ problems about it:1)how to define the initial/bounary conditions;2)the model equation should been solved coupled with NS equations or not;3)which parameters influence its computation efficiency and accuracy. Thank you for response!
JJ
Old   June 11, 2006, 20:02
Default Re: some questions about SA turbulence model?
J.Jiang
Hi, Have anybody done any work about that?I think 'yes'.So I wish you can give me some advice or any other help. Thanks very much!
JJ
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 20:21
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
turbulence model equation Andy Chen FLOW-3D 4 January 1, 2010 21:45
Turbulence model Herry Phoenics 1 May 29, 2003 13:19
turbulence model question Jason Wei Main CFD Forum 1 May 6, 2003 00:45
