XOOPIC/OOPIC code
Old   April 13, 2013, 22:20
Default XOOPIC/OOPIC code
mahsoun dincoz
mahsoun dincoz is on a distinguished road
Hi
I want to simulate plasma gas using XOOPIC/OOPIC code available from (http://ptsg.egr.msu.edu/) .I have visual stdio and dev-c++ softwares and my O.S. is windows 7. I have tried too much to run these code but I was unsuccessful , Please help me If You know any thing about
Regards
mahsoun dincoz is offline   Reply With Quote
Old   April 14, 2013, 08:47
andy
andy_ is on a distinguished road
Originally Posted by mahsoun dincoz View Post
Hi
Regards
These look like typical university research codes. They will run easiest on linux systems and may well use libraries that are not easily available on Windows. If you are inexperienced at working with such codes then you should expect problems.
I don't know your position but perhaps the easiest way forward is to install linux and then compile and run the software as intended. Depending on what you find, moving it to Windows may or may not be practical. If you are mainly Windows based and your PC has enough memory installing a version of linux inside virtualbox is a flexible way to go about things.
andy_ is offline   Reply With Quote
Old   April 14, 2013, 15:28
Smile
mahsoun dincoz
Too thanks for your help
I will install Linux to test does it works or not. at (http://ptsg.egr.msu.edu/pub/codes/xo...an/sec5_2.html) installing this code is mentioned, as you can see, to run these codes g++, libg++, libtcl.a, libtk.a, libXpm.a is needed.I have found g++ for Linux/Unix. but I have problem with the others. do you know how I can get other libraries for Linux/Unix?
Regards
Old   April 14, 2013, 16:53
andy
Regards
You install them using the package manager for your particular version of linux. Normally a graphical package manager is under system or administration or something similar. There will be help/support pages describing this sort of thing for your particular version of linux.
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 12:30
How to make code run in parallel? cwang5 OpenFOAM Programming & Development 1 May 30, 2011 04:47
Open Source Vs Commercial Software MechE OpenFOAM 28 May 16, 2011 11:02
Small 3-D code Zdravko Stojanovic Main CFD Forum 2 July 19, 2010 10:11
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 11:44
