how to deal with the wall boundary of les?
Old   June 11, 2006, 19:20
Default how to deal with the wall boundary of les?
mud2003
Ask for help! In the les turbulent model, how to deal with the wall boundary? And if the y+ is needed , how to calculate it?
Old   June 12, 2006, 13:17
Default Re: how to deal with the wall boundary of les?
agg
In the boundary layer, you must use DNS resolution, in other words, y+ < 1. (see any standard book on turbulence for y+ calculation)
Wall models are an alternative, and you might want to try them.
Old   June 13, 2006, 06:21
mud2003
agg, can talk about the calculation of y+ in les ? The y+ fomulation need k, but how to get it in les??
Old   June 15, 2006, 09:29
agg
y+ is just a non-dimensional distance based on friction velocity
y+ = y*utau/viscosity utau = (wall shear stress/density)^0.5
You can calculate wall shear stress from LES using velocity gradient at the wall and hence y+
Old   June 17, 2006, 13:38
mud2003
agg, you mean the wall shear stress can get by using velocity gradient at the wall, so must use DNS resolution, in other words, y+ < 1??? But when the y+>30, the wall shear stress is diff to get?
Old   June 18, 2006, 18:39
agg
When y+ is not resolved, you can use wall models.
An example would be to use:
1) u+ = y+ in the viscous sublayer (if y+ <= 10) 2) u+ = 2.5 ln(y+) + 5.5 (if 10 < y+ <= 300)
For (2), an iterative procesure is required, since wall stress is an unknown in both LHS and RHS.
Once u+ is known, you can back calculate u at that point.
Best information can be found in papers. You should be able to find papers with LES using wall models.
Old   June 18, 2006, 19:19
Halim
Visit here http://www.lstm.uni-erlangen.de/~breuer/ and see this
CFD - Code LESOCC (Large Eddy Simulation on Curvilinear Coordinates)
Numerical Method
Discretization
Subgrid Scale Model
=== Wall Boundary Conditions ===
Good Luck!
Halim
Old   June 20, 2006, 11:42
mud2003
i am reading, thanks halim!
Old   June 27, 2006, 05:36
aiya
hi....halim
the Code LESOCC is shared?
where can get some code for learning?
Old   June 27, 2006, 18:21
Halim
(1) Ask to Dr. Breuer (E-mail: breuer_at_lstm.uni-erlangen.de )
(2) Sorry, I do not know. I know that if you buy this book, you can have a source code for LES. "Fluid Flow Phenomena : A Numerical Toolkit" by Paolo Orlandi, Kluwer Academic Publishers, 2000.
Halim
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
Simple Wall Boundary Conditions for Turb. Flow Greg Perkins Main CFD Forum 4 May 28, 2002 23:10
