-   -   BEM Analysis of NREL phase VI turbine (http://www.cfd-online.com/Forums/main/116202-bem-analysis-nrel-phase-vi-turbine.html)
er_ijaz April 15, 2013 06:33
Hi all
i tired MATLAB code for finding the power coefficient for NREL Phase VI turbine.But my answer is very below the experimental value.
i took the hub radius as 1.257 m where the actual airfoil starts
I get power coefficent very below the experimental
suddenly I got a doubt whether it is because of the hub diameter
Actually blade cyclindrical section which is attached is 0.508 m and from 0.883 m to 1.257 m it undergoes transition from cylinder to airfoil.
so in BEM I took the hub diameter is 1.257 m where the airfoil starts
kaya April 15, 2013 09:18
Hello er_ijaz,
The root section shouldn't affect that much actually. What are the expected and calculated power coefficients?
er_ijaz April 15, 2013 09:26
Values of Power Coefficient
windspeed in m/s 7 10 13 15 20 25
experimental(NREL) 0.369 0.209 0.094 0.054 0.0218 0.0149
With out correction 0.304 0.096 0.0035 0.009 0.0053 0.00516
Tiploss correction 0.283 0.0939 0.0118 0.016 0.0060 0.00555
kaya April 15, 2013 10:32
First of all, I would include the part from root to the first airfoil section. Than I would compare my Cps with NREL s again.
Still difference? Then I would start having concerns about the tabulated Cl Cd data you use if you got them from another source. (I assume your BEM is correct.. paste your code and I can have a look)
er_ijaz April 15, 2013 10:36
can u email me bro
my email id is er_ijaz@yahoo.com.I,m in mobile.I will forward u my code
kaya April 15, 2013 10:41
would be easier to discuss it here if you paste the main solver here. but you can of course mail me also.
er_ijaz April 15, 2013 11:55
ur email id
Brother can i have ur email id .my id is er_ijaz@yahoo.com
kaya April 15, 2013 12:04
gadruno[ at ] g mail.com
kaya April 15, 2013 13:22
I didn't quite understand the way you get the Cl Cd coefficients. Don't you have a tabulated data for it? Or is this a fitted curve provided from NREL?
er_ijaz April 17, 2013 04:20
regarding cl and cd values
Hi
i created an empirical formula based on the experimental results by using genetic programming for cl and cd values.
And sorry for late reply .I will email u the experimental values
other than that did u find any mistakes
kaya April 17, 2013 06:44
don't send me any data. I don't have time to debug your code yet I can direct you to find your own problem.
plot your measured CL vs aoa - CD vs aoa and plot your CL_empiric - aoa and CD_empiric vs aoa up on them. and lets see how correct your empiric curve.
on the other hand, did you check the measured CL and CD whether if its measured at the correct Reynolds? I don't know how big is this turbine but CL and CD datas are very sensitive between RE 100k and 1m.
er_ijaz April 17, 2013 08:04
regardin cl and cd
hi
ya i had plotted n chcked the cl n cd values(empirical) with the experimental.There is no much difference.Anyways thanks for ur help.If u debug pls let me know .anywhere logic is not ok
