Friction at walls
Old   April 17, 2013, 04:41
Default Friction at walls
roupcik is on a distinguished road
Hi everyone,
Problem description:
Fuel zone( represented by porous zone ) is vertically as well as horizontally separated to sectors in order to model areas with different hydraulics and power distribution. Although there was set zero shear stress (Picture 1) on all separation walls, the coolant has a lower velocity at walls (seems like nonzero wall friction). You can see the lower velocity on velocity contours: horizontal (Picture 2) and vertical (Picture 3). The friction wall effect is undesirable.
Question:
How to set boundary conditions to eliminate undesirable „friction forces“ that have occurred at separating walls?
Additional information:
Description of the model:
1. 3D model represents a typical spent fuel pool coolant.
2. Regions of fuel channels are set as „porous zones“.
3. Flow of coolant (water) is forced up from the bottom of the pool.
4. Heat generation in each fuel channel is homogenous.
Setting:
Solver – pressure based, absolute, steady, gravity
Models – energy, k-epsilon, realizable, standard wall functions
Methods – SIMPLE, second order
Regards, roupcik.
roupcik is offline   Reply With Quote
Thread Tools
Trackbacks are On
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 10 February 5, 2014 12:17
multiphaseEulerFoam loosing fluid with zeroGradient for p on walls??? petr.f. OpenFOAM Running, Solving & CFD 0 November 28, 2012 07:33
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 20:11
Openfoam friction coefficient differences. Peter88 OpenFOAM Post-Processing 0 February 8, 2011 11:07
thermal conditions of walls Stefan FLUENT 2 March 23, 2003 07:17
