BEM Analysis of NREL phase VI turbine
Old   April 15, 2013, 07:33
Default BEM Analysis of NREL phase VI turbine
ijaz fazil
er_ijaz is on a distinguished road
Hi all
i tired MATLAB code for finding the power coefficient for NREL Phase VI turbine.But my answer is very below the experimental value.
i took the hub radius as 1.257 m where the actual airfoil starts
I get power coefficent very below the experimental
suddenly I got a doubt whether it is because of the hub diameter
Actually blade cyclindrical section which is attached is 0.508 m and from 0.883 m to 1.257 m it undergoes transition from cylinder to airfoil.
so in BEM I took the hub diameter is 1.257 m where the airfoil starts
er_ijaz is offline   Reply With Quote
Old   April 15, 2013, 10:18
Kaya Onur Dag
kaya is on a distinguished road
Hello er_ijaz,
The root section shouldn't affect that much actually. What are the expected and calculated power coefficients?
kaya is offline   Reply With Quote
Old   April 15, 2013, 10:26
ijaz fazil
Values of Power Coefficient
windspeed in m/s 7 10 13 15 20 25
experimental(NREL) 0.369 0.209 0.094 0.054 0.0218 0.0149
With out correction 0.304 0.096 0.0035 0.009 0.0053 0.00516
Tiploss correction 0.283 0.0939 0.0118 0.016 0.0060 0.00555
Old   April 15, 2013, 11:32
Kaya Onur Dag
First of all, I would include the part from root to the first airfoil section. Than I would compare my Cps with NREL s again.
Still difference? Then I would start having concerns about the tabulated Cl Cd data you use if you got them from another source. (I assume your BEM is correct.. paste your code and I can have a look)
Old   April 15, 2013, 11:36
Default can u email me bro
ijaz fazil
my email id is er_ijaz@yahoo.com.I,m in mobile.I will forward u my code
Old   April 15, 2013, 11:41
Kaya Onur Dag
would be easier to discuss it here if you paste the main solver here. but you can of course mail me also.
Old   April 15, 2013, 12:55
Default ur email id
ijaz fazil
Brother can i have ur email id .my id is er_ijaz@yahoo.com
Old   April 15, 2013, 13:04
Kaya Onur Dag
gadruno[ at ] g mail.com
Old   April 15, 2013, 14:22
Kaya Onur Dag
I didn't quite understand the way you get the Cl Cd coefficients. Don't you have a tabulated data for it? Or is this a fitted curve provided from NREL?
Old   April 17, 2013, 05:20
Default regarding cl and cd values
ijaz fazil
Hi
i created an empirical formula based on the experimental results by using genetic programming for cl and cd values.
And sorry for late reply .I will email u the experimental values
other than that did u find any mistakes
Old   April 17, 2013, 07:44
Kaya Onur Dag
don't send me any data. I don't have time to debug your code yet I can direct you to find your own problem.
plot your measured CL vs aoa - CD vs aoa and plot your CL_empiric - aoa and CD_empiric vs aoa up on them. and lets see how correct your empiric curve.
on the other hand, did you check the measured CL and CD whether if its measured at the correct Reynolds? I don't know how big is this turbine but CL and CD datas are very sensitive between RE 100k and 1m.
Old   April 17, 2013, 09:04
Default regardin cl and cd
  #12
ijaz fazil
hi
ya i had plotted n chcked the cl n cd values(empirical) with the experimental.There is no much difference.Anyways thanks for ur help.If u debug pls let me know .anywhere logic is not ok
aerodynami, nrel phase 6 validation, windturbine
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 15:07
analysis of wind turbine blades sharuk Main CFD Forum 7 December 9, 2014 19:59
Analysis of Wind turbine blade ( 3D aerofoil) by Ansys 12 rsskarthikeyan FLUENT 5 October 13, 2012 23:29
blade analysis of gas turbine Fayyaz Husain Main CFD Forum 1 March 3, 2010 02:13
two-dimensional gas turbine analysis Muhammad Usman Qureshi Main CFD Forum 0 March 14, 2007 13:01
