April 18, 2013, 06:19 |
heat flux-fluent-value
Laura
Rep Power: 12 |
Hi there, I am modelling a box with 2 inlets and an outlet and with a heater of 30W. I would like to observe the natural convection - temperature changes.
I am using ideal-gas incompressible, laminar flow. t initial is 293K and the temperature of the heater rises to around 460K when I used pseudo transient. I did the experiment manually and the temperature rose only by 7 degrees. does anyone know why this is happening? tnx |
April 21, 2013, 05:00 |
Majid Mostafazadeh
Rep Power: 14 |
Hi
What is your fluid for experiment and simulation? |
April 21, 2013, 05:23 |
Laura
Rep Power: 12 |
Air at 20 degrees
April 21, 2013, 06:28 |
Majid Mostafazadeh
Rep Power: 14 |
Choose Boussinesq model for density. Consider the gravity. Run your case again...
Display Modes | |
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 05:28 |
How to define the heat flux in the interior interface between two phases | fangdian | FLUENT | 1 | November 18, 2013 08:23 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 23:22 |
Need Help on Heat Flux Profile within Pipe Wall | mep10jl | FLUENT | 3 | June 6, 2011 18:08 |
How to find the inbuilt equation in fluent for Heat Transfer Flux? | rohitjvbibin | Main CFD Forum | 0 | October 26, 2010 06:51 |
