-   -   Roe implement about preconditioning (http://www.cfd-online.com/Forums/main/11640-roe-implement-about-preconditioning.html)
ricklee June 15, 2006 23:26
Dear all:
I used weiss and smith's preconditioning in my
compressible code. But I still confused about the Roe
scheme.
Original Roe: F = 0.5*(F_L+F_R)+0.5*abs(A)*(U_R-U_L)
preconditioning: F = 0.5*(F_L+F_R)+0.5*P*abs[(P^-1)*A]*(U_R-U_L)
or F = 0.5*(F_L+F_R)+0.5*P*abs[(P^-1)*A*M]*(Up_R-Up_L)
here
M = partial(U)/partial(Up)
U = [rho rho*U rho*E]
Up = [P U T]; T = P/rho
Which is correct for preconditioning?
AJS June 16, 2006 02:58
Re: Roe implement about preconditioning
Hi, THe second form is the correct one - you want to work entirely with the Up vector. See recent articles from Hosangadi et al or Whitfield et al.
ajs
ricklee June 16, 2006 14:00
Thank you for your answer,AJS.
I try the first and the second form in my code.
But It still didn't convergence.
Can you give some reference ?
In Eigenvalues and Eigenvector, I used AIAA papre about
Overflow code. I check many times and I think it was right.
Why it did't covergence?
ricklee June 16, 2006 15:07
Sorry, I forget write my BC.
I test the flow in a channel. The inlet velocity is
0.46 m/s. The outlet condition is Pressure = 1atm.
In the wall, P(nx)=P(nx-1) Neumann condition.
Besides, I used MUSCL and 3-stage Runge kutta.
But it didn't convergence.
ganesh June 17, 2006 00:53
Dear Ricklee,
If you are having problems with convergence, you can try the following
1. Use the preconditioned Roe scheme itself to run a compressible flow problem, say at M=0.4, switching off the preconditioning option, if you like to. This would help you to find if the preconditioned Roe scheme works well or not.
2. If things are working fine, and you have some problems of convergence, try the following. There is a quantity Uref used in the modified eigen values. Try out the following way of defining Uref rather than the one in Weiss-Smith paper (In fact they are not very different)
Uref = min(a,max(q,K*q_inf))
where a is the local sonic velocity, q is the local velocity( sqrt(u**2 + v**2) and q_inf is the freestream velocity. K is a constant which is generally taken 1. Try this with K=1 and higher K. I am nearly sure things will get sorted out, becasue it worked for me this way. For a liitle more details, look at New Features in CFL 3D. You can get this by just googling it
Hope this helps
Regards,
Ganesh
Ricklee June 18, 2006 21:11
Dear ganesh:
First, thanks for your answer about the convergene
problem.
I solve the problem about channel flow. But in the
back-ward-facing-step model, it didn't covergence.
In the reverse flow region, the velocity profile has
oscillation.
I used the MUSCL , Roe scheme , three stage Runge
Kutta , Weiss and smith preconditioning.
Roe implement:
here
U = [rho rho*U rho*V rho*W rho*E]
Up = [P U V W T]; T = P/rho
In the eigenvalues and eigenvectors. I used the AIAA paper
about Overflow.
AIAA 97-0644 'recent Enhanecements to OVERFLOW'
Can you give me some suggestions?
ganesh June 19, 2006 08:46
Dear Ricklee,
I also had problems initially about convergence. Some problems converged well, but others did not. It was then that I came across the CFL3D: New Features section, where the issue of a constsnt in the reference velocity was discussed, as in my earlier post. I have sucessfully solved lid driven cavity, backward facing step, flow past airfoil and flow past cylinder among others. Just make sure that your code first runs for a compressible flow problem (as I have said in my earlier post) and then try increasing the constant, to improve the convergence. You could also try a coarser grid and see if the problem persists.
Hope this helps
Regards,
Ganesh
mar July 7, 2006 06:14
lower the time-step
