boundary conditions compressible flow
Old   June 7, 2006, 11:55
Default boundary conditions compressible flow
newposter
hi,
I want to simulate a shock in laval nozzle with my pressure-correction based SIMPLE code. I want to prescribe at Inlet: u,v,w and T at the Outlet: p_Stat
I can`t get convergence, the residuals are oszillating.
What can I do, please help?!
Old   June 7, 2006, 21:44
Default Re: boundary conditions compressible flow
khai ching
What if you try to fix the stagnation properties at the inlet, e.g. Total Pressure, Total Temperature as well as the flow angle
Old   June 8, 2006, 02:45
newposter
That`s possible and working! My question is only if it`s possible to fix u,v,w and T and to get results with shocks and so on... Thank`s...
Old   June 9, 2006, 16:41
Mani
I don't see the point of doing that. The total pressure and total temperature are "natural" inlet conditions, because they are usually known from experiments, and they can be viewed as independent from the exit static pressure. Inlet flow angles are quasi known because of the duct geometry. On the other hand, the inlet velocity is not usually known in internal flow problems. Think physically: Flow is determined by pressure gradients, especially in internal flow, and your CFD should be driven by a natural condition. You ought to have some information on (total) pressure at the inlet. As a general remark: The number of conditions that you need to provide depend on the number of characteristics traveling into/out of the domain at the boundary, and that number is well known. However, the number alone does not guarantee convergence, or even existence of a unique solution. You have to choose a reasonable (preferably physical) combination of boundary conditions.
Old   June 16, 2006, 17:10
newposter
Thank you very much!!
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
boundary conditions for 3D channel flow with heat transfer Aloex FLUENT 1 February 22, 2011 12:28
boundary conditions for boundary layer flow A. Al-zoubi CFX 0 November 3, 2007 07:11
compressible flow boundary conditions yangqing FLUENT 2 January 22, 2002 10:19
