Values of k & epsilon in the moving wall
Old   August 16, 1999, 09:59
Default Values of k & epsilon in the moving wall
ghlee
Dear Friends! I ask you some questions about imposing the k & epsilon in the moving wall. I have calculated the unshrouded centrifugal type turbomachinery. I used the relative velocity, rotating coordinate, standard k-epsilon turbulence modeling. In imposing the wall B.C, stationary part( e.g shroud casing, vainless diffuser) will have the circumferential velocity (-omega * vec r). And I treated in these parts as walls in order to use wall function. How do I impose the value of k & epsilon values. Would you like to give me an answer. Thank you for reading.
Old   August 16, 1999, 12:42
Default Re: Values of k & epsilon in the moving wall
John C. Chien
(1). I am not sure I understand your question. (2). The use of the wall function depends on the calculation of the wall shear stress, which should be part of your flow field solution. (3). As for the boundary conditions for the k & epsilon equations, it depends on the particular model and method used. It is a good idea to read the related technical papers. (or the user's guide)
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
How to make boundary layer mesh moving with wall wayne FLUENT 3 June 11, 2008 23:23
modelise the motion of the fluid by a moving wall samnetmoon FLUENT 1 April 21, 2008 07:06
moving wall wim vos FLUENT 1 March 30, 2004 18:20
