drop formation
Old   June 18, 2006, 22:02
Default drop formation
fly
Hi,I am now trying to simulate the drop formation from a capillary pipe under the gravity. I have tried to use flow-3d to do the job and make the pressure as the motivation,but failed. Can anyone give me some suggestions? Thanks in advance!
Old   June 18, 2006, 22:04
Default Re: drop formation
fly
forget,the radius of the pipe is 1mm. Of course surface tension is important,so I choose Flow-3D.
Old   June 19, 2006, 07:26
Jim_Park
The technical support at flow science has always been great. Did you ask them for help?
Old   June 19, 2006, 07:46
fly
In the examples with flow-3d the gravity is ignored. Considering the gravity I have tried about 100 times but faild. The necking can't appear.
Old   June 19, 2006, 23:00
Tom
As suggested by Mr. Park, please contact Flow Science support at support@flow3d.com for help. Let them know the details of your problem, what you're trying to learn (as well as where you're at) and I'm sure you'll get great help.
Old   June 20, 2006, 00:35
fly
Thank you for your advice. Best wishes!
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
Drop formation in 2D in_flu_ence OpenFOAM Running, Solving & CFD 0 February 3, 2008 08:45
Drop formation fly CFX 0 June 20, 2006 00:50
Drop deformation Ron FLUENT 2 June 24, 2004 06:05
a problem in calculating pressure drop in Fluent? yu chun FLUENT 1 May 18, 2004 03:40
