May 3, 2013, 06:07 |
discretisation
ramin abedifard
Rep Power: 13 |
Hello
I want to discretise one term of non fourier heat transfer equation with volume control method. I try to do it, but i cant. this term is: d2(cp u T)/(dt dx) that we have cp(T),u(x,y,t),T(x,y,t) T:temperate t:time thank you Last edited by ramin; May 3, 2013 at 16:32. |
May 3, 2013, 08:34 |
Filippo Maria Denaro
Rep Power: 71 |
I have some doubt about your symbolism, you are referring to as a first time derivative or a second mixed x,t derivative....?
May 3, 2013, 16:40 |
ramin abedifard
Rep Power: 13 |
May 3, 2013, 17:52 |
Rep Power: 71 |
May 4, 2013, 03:16 |
ramin abedifard
Rep Power: 13 |
May 4, 2013, 04:57 |
Rep Power: 71 |
May 4, 2013, 07:13 |
ramin abedifard
Rep Power: 13 |
It is a hyperbolic heat transfer equation. It should be discretised base on versteegَ s book(An introduction to computational fluid dynamics) and with volume control method.
May 4, 2013, 13:46 |
Rep Power: 71 |
Your question is not clear to me... to the best of my knowledge, a term like d2T/dxdt never appears in the original heat equation....
hybrid time-space derivatives usually appears when you use some time-integration method of the class of the Lax-Wendroff. But in such cases, the original equation is substituted into the derivative. |
May 4, 2013, 18:26 |
#9 | |
ramin abedifard
Rep Power: 13 |
This term is very small, since it has a very small fixed coefficient. This coefficient shows the speed of heat propagation is not infinite. |
May 5, 2013, 04:13 |
#10 | |
Rep Power: 71 |
Again, the real problem is not in the discretization of a single term (is quite simple to do on a time-space grid) but care in the discretization of the model equation is required. You said it is hyperbolic, therefore the discretization of the whole model must be stable and accurate, but if the equation is also non-linear other requirements can be necessary. |
May 5, 2013, 05:44 |
#11 | |
ramin abedifard
Rep Power: 13 |
Display Modes | |
8th order polynomial function(VOF smoothening) + ENO discretisation | bharat.cmeri | FLUENT | 1 | July 4, 2012 11:51 |
Transient term discretisation scheme | Batis | CFX | 2 | August 23, 2010 20:17 |
Second Order Discretisation with Porous Media | giogio | FLUENT | 1 | March 21, 2008 12:29 |
Discretisation scheme in CFX-1st or 2nd order? | Pete | CFX | 10 | January 12, 2005 12:48 |
compressive discretisation scheme | Jennifer Haque | CFX | 7 | July 29, 2004 05:00 |
