Axial Turbine- Temperature at Outlet
Hi..
I am doing FSI analysis of Axial flow turbine, Transient flow analysis, air medium, with k-epsilon turb. model. Pressure-In- 2bar. Pressure-out-Gauge. are BCs. Sliding mesh-for rotating part-10k rpm. Inlet temp-920k, Outlet-backflow-300k default. I want to evaluate the outlet temperature.. How it can be done. With current BCs am getting required pressure distribution. But temperature remains same from inlet to outlet.. its not varying. Which Bcs will be suitable. Need yur valuable advice . Thanks Gowrav |
