Laplace Eqn. Finite Diff. Error Problem
Old   April 4, 2015, 17:33
Default Laplace Eqn. Finite Diff. Error Problem
Gorkem Ocalan
gorkemocalan is on a distinguished road
I have some problems about error analysis of Laplace Eqn. in 2D. I generated coefficient matrix and right-hand side vector as Au=b format properly and solved u=A\b.
I calculated analytical solution with respect to boundary conditions which are
u(x,0)=0 ,u(x,1)=x-x^2, u(0,y)=0, u(1,y)=0.
There is a problem about error. I was expecting to observe the decrease in error by making the mesh finer. But it did not happen in that way. 41x41 mesh gave better error result than 81x81 mesh.
I also attached the code (MATLAB) for the people who are interested in.
Thanks for your concern...
gorkemocalan is offline   Reply With Quote
Old   April 4, 2015, 17:46
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
indeed, the error must diminuish ... how do you invert A? check if A*A^-1 is the identity matrix (note that u=A^-1*b)
Check also the exact solution
FMDenaro is offline   Reply With Quote
Old   April 5, 2015, 01:06
Alex
H0T_S0UP is on a distinguished road
Be careful with MATLAB. Its matrix operations don't always work the way you'd expect.
H0T_S0UP is offline   Reply With Quote
Eliminating exchange energy between phase in Granular Temperature diff eqn. cfdbusiness FLUENT 0 February 2, 2010 22:30
Finite volumes vs. finite elements: applications Lionel S. Main CFD Forum 10 January 22, 2007 10:51
Laplace operator in finite element formulation Rafael Main CFD Forum 2 October 19, 2004 21:09
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
