-   -   Solid body becoming source or sink (http://www.cfd-online.com/Forums/main/11730-solid-body-becoming-source-sink.html)
zonexo June 28, 2006 20:35
hi,
i'm using the fractional scheme to solve the 2d NS eqn. I found that after solving the poisson eqn, sometimes the body will become a sink (ie it seems to be sucking in the flow velocity ) or a source (ie the flow velocity is flowing out).
May I know why this is happening? What is the source of the problem for the above 2 scenario?
Tks!
Jim_Park June 28, 2006 21:03
Re: Solid body becoming source or sink
Is this for incompressible flow?
What do you expect to happen at the body-fluid interface? If you expect zero-flux (or zero normal velocity) at those surfaces, the Poisson equation boundary conditions on those surfaces need to express that.
I don't know "the factional scheme" or how it solves the pressure (Poisson) equation, so that's as far as I can take it.
Maybe someone else can add to this ...
zonexo June 28, 2006 23:22
ya, it's for incompressible flow. for stationary body, u=v=0, dp/dn=0. however, I believe there's some error in the implementation of the BC hence resulting in the body changing to a sink or source.
I'm wondering if anybody has experience before and therefore know the cause of it....
