-   -   Turbulence Model for low Reynolds Number (http://www.cfd-online.com/Forums/main/11752-turbulence-model-low-reynolds-number.html)
Muhammad Shakaib July 3, 2006 08:04
Dear CFD people
My problem includes flow over cylinders in narrow channel at low Reynolds Number. Which turbulence model will be more suitable.
ganesh July 3, 2006 08:28
Re: Turbulence Model for low Reynolds Number
Dear Muhammad,
I would suggest a k-family turbulence model with low Re correction, like the Low Re formulation of k-e model.
Regards,
Ganesh
V. Kumar July 3, 2006 15:42
If two-equation model does your job (no adverse pressure gradients and boundary layer separation), then Mentors SST model should do fairly well.
If you want to compute with Second-moment closures, I suggest to adopt models which use omega equation near the wall and epsilon equation away from the wall. In CFX this model is named as Second-moment omega model.
hope this will help you.
