-   -   Projection-Method with grid generated via Thompson algorithm (stretching function) (http://www.cfd-online.com/Forums/main/117607-projection-method-grid-generated-via-thompson-algorithm-stretching-function.html)
stefanbj May 12, 2013 00:08
Hi all,
I'm trying to implement the projection method on a flow past a cylinder problem.
I have generated a grid for the cylinder via Thompson algorithm of the Poisson equations. Therefore the grid is (very) stretched and curvilinear.
When I descretize the NS equations, what is the appropriate stretching function I should use?
For example, for x=x(\xi,\eta)
\frac{du}{dx} = \frac{du}{d\eta}\frac{d\eta}{dx}+  \frac{du}{d\xi}\frac{d\xi}{dx}
what is the appropriate expression for \frac{d\eta}{dx},\frac{d\xi}{dx}?
