one-way vs two-way FSI for stall deformation of a hydrofoil
Old   February 7, 2014, 13:00
Default one-way vs two-way FSI for stall deformation of a hydrofoil
Alex
Kina is on a distinguished road
I am currently comparing the flow around a hydrofoil for a rigid body (CFD) and an elastically deformable body (FSI). As my computer takes a very long time getting results I asked myself if it would be possible to go for a one-way FSI and then simply remesh the deformed model and rerun the CFD again with a "rigid deformed model". This seems to be about accurate for regular deformation. However, when it comes to stall the pressure on the foil decreases and the deformation also decreases with it. When I now rout back the deformation to the CFD interface, wouldn't that cause huge errors? I am just wondering because I have not found any data on that topic.
Thank you!
Alex
Kina is offline   Reply With Quote
Old   February 8, 2014, 11:01
Totalsim's Avatar
Jon
Totalsim is on a distinguished road
I think it all depends upon the amount of deformation that is occurring and its effect upon the flow.
It may be that the deformation is relatively small and doesn't significantly affect the flow regime. Conversely if the deformation is capable of causing stall etc then it needs a more tightly coupled solution.
TotalSim CFD Engineer
www.totalsimulation.co.uk
Totalsim is offline   Reply With Quote
Old   February 8, 2014, 12:03
Alex
As I am dealing with fiberglass, I have tip deformations of about 19mm for a length of rougly 240mm. So the deformation is quite large. My initial thought was that in the presence of stall, the initial deformation for the first coupling step might be not that large but as soon as the foil tip deforms, it recovers from stall and develops a higher pressure that is not captured in a simple "i put pressure data in fea and run cfd for the deformed mesh". I am still not sure, but that's the way I imagine it.
how to define a shape deformation using the grid deformation variables (FSI problem) momo_sjx SU2 Shape Design 6 June 7, 2015 22:29
[ICEM] 2 way FSI, CFX + Mechanical + ICEM, Remesh, Deformation due to fluid flow binoyjjohn ANSYS Meshing & Geometry 8 June 25, 2014 09:00
MFX FSI for linear case. Help needed. peiji1984 CFX 4 February 22, 2011 12:11
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
FSI with "solid deformation" siavashghassemi CFX 3 September 4, 2007 16:35
