matrix dissipation
Old   July 12, 2006, 09:17
Default matrix dissipation
Simon
My main question is: How to implement a matrix dissipation method on an unstructured FV, cell centred, Runge-Kutta sheme?
Can anyone give me some references on matrix dissipation applied with unstructured grids?
Thanks
Old   July 14, 2006, 02:55
Default Re: matrix dissipation
O.
I assume you are talking about a central discretization + a matrix dissipation term.
I don't know any papers, unfortunately.
Isn't any upwind scheme a matrix dissipation scheme as well?
For example the Roe scheme across an interface can be written as:
F = 1/2*(F(Q_l) + F(Q_r)) - 1/2*|A|*(Q_r - Q_l)
with Q_l and Q_r beeing the extrapolated values from the left and right side and |A| the Roe matrix. In this case the matrix is based on physical considerations (direction of influence, eigenvalues). I think that you could in principle use any other matrix as well. How you extrapolate Q_l and Q_r defines the order of your scheme.
'hope this helps, or did I miss anything out??
Old   July 14, 2006, 08:38
Simon
Thanks.
Yes I mean "central discretization + a matrix dissipation". My main concern is the implementation/calculation of |A| in an unstructured framework? How does the lack of direction of the grid influences the calculation of |A|?
Old   July 17, 2006, 03:12
O.
You do have a direction. If you compute the flux across an interface than the interface has a normal and thus you can differentiate between an upwind and a downwind side. But it is true that things can be awkward. Something like the next neighbour in upwind direction is impossible on triangular grids. Unfortunately I have no experience with matrix dissipation schemes. For upwind schemes you can formulate something by using a local direction (e.g. interface normal) and the gradients in the two cells adjacent to your interface (for more than 1st order).
If you find/found a good paper on this, I'd be interested in the reference.
Old   July 17, 2006, 08:57
Cut cell
This is classic, it should answer all you questions:
http://hdl.handle.net/2002/13559
which should be the same as:
http://library-dspace.larc.nasa.gov/...dle/2002/13559
Cheers
Andy
Old   July 18, 2006, 01:59
O.
That describes a very classic upwind solver.
Force can not converge colopolo CFX 13 October 4, 2011 22:03
CFX12 rif errors romance CFX 4 October 26, 2009 13:41
OpenFOAM version 1.6 details lakeat OpenFOAM Running, Solving & CFD 42 August 26, 2009 21:47
Dissipation in Harten-Yee and Davis-Yee TVD Scheme cfdxue Main CFD Forum 0 April 29, 2008 10:45
Dissipation rate access K. Kevala FLUENT 0 July 14, 2004 11:11
