SIMPLE algorithm and coefficient
Like Tree1Likes
  • 1 Post By RodriguezFatz
Old   May 22, 2013, 03:58
Exclamation SIMPLE algorithm and coefficient
sina gilassi
sinagilassi is on a distinguished road
According to the book `An introduction to computational fluid dynamic the finite volume method, H K Versteeg, first edition`
page 139, the momentum equations are defined as follows:
a(i,J)u(i,J) = SUM(a(nb)u(nb)) + (P(I-1,J) - P(I,J))A(i,J) + b(i,J)
As SIMPLE algorithm needs P(guess) to change the above equation to scaler equation and then for each velocity u and v we have an equation.
My question is about the coefficient of above equation which contains the F and D, both F and D equation contains u and v values.
in page 142, the description of SIMPLE algorithm :
1) P(guess)
2) scaler equation --> iteration --> result = v(star) and u(star)
3) find P' with the continuity equation
4) correct all P,u and v
5) check the convergence
6) yes or no and loop
my question is the coefficients ??!!!!
their elements should be multiplied by the u(star) and v(star) ??? i am totally
Someone helps me
sinagilassi is offline   Reply With Quote
Old   May 22, 2013, 04:20
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Now, what exactly is your question? Do you want to know how the coefficients are calculated, since they need the unknown velocities?
sinagilassi likes this.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   May 22, 2013, 04:28
sina gilassi
yes exactly, yes, yes, ... the mentioned book says:
1) guess P
2) v (star) and u(star) will be calculated ?? HOW they are calculated when the coefficient are unknown ??
Old   May 22, 2013, 04:43
Philipp
You always need to initialize all the variables. Also the velocities. Thus, you can use the initializations to calculate the coefficients. Later on you can use the "last known" velocities for that.
Old   May 22, 2013, 05:27
sina gilassi
thank you man for all the responses
but I am still thinking
Implementation of Simple Algorithm JunaidAhmad Main CFD Forum 40 November 4, 2017 13:16
Pressure coefficient in SIMPLE Algorithm m.iran Main CFD Forum 2 August 22, 2009 01:36
Question to SIMPLE algorithm by Patankar's book. Rafal Main CFD Forum 2 December 21, 2005 03:48
SIMPLE Algorithm shreya Main CFD Forum 3 February 22, 2004 05:54
2D CFD code using SIMPLE algorithm bfan Main CFD Forum 3 June 22, 2002 22:01
