mesh size: getting worse results with finer mesh |
June 10, 2015, 05:08 |
Ali Adel
Rep Power: 11 |
Hello everybody,
I am using a model which is dealing with the turbulence and waves, the problem when I made the validation for the programme with the experiment data, it showed a good result; however, when i reduced the mesh size to get more accurate solution, the results getting far from the experiment data and the relative error between the experiment data and the numerical result increased and reached to 50% (when i used small mesh size) why that happened???? any explain for that case?? Thank you in advance for any answer, |
June 11, 2015, 07:11 |
Philipp
Rep Power: 26 |
Possible reasons (among others):
The skeleton ran out of shampoo in the shower. |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
