July 19, 2006, 09:54 |
mesh guidelines for reattachment
Hi!
what are the guidelines, meshing the zone at the wall, where e.g. reattachment takes place?? I am using k-e and k-w turb. modells with different wall functions. Results are ok, except close to the reattachment point (cylindrer in axial flow). Is ther a y+ value, that has to be considered?? y+ values for the wall are well known... but they are valid only for equilibrium BL. Also, y+ is allways zero at the reattachment point! Any suggestions?? Ralf |
July 20, 2006, 06:48 |
Re: mesh guidelines for reattachment
Hi Ralf, I analysed the same problem. In the reattachment point, it's difficult to achieve solutions similar to sperimental measures, also if you refine the mesh a lot. I suggest you to begin from a coarse mesh with a few points and gradually refine it until you achieve a small numerical difference between the fine mesh and its previous.
Since the problem in reattachment point is not mesh dependent, to study turbulente flow and its laminar sublayer, the y+ should be on the order of unity (y+<5). y+ dependes on the wall friction stress. The wall friction coefficient is always zero at separation and reattachment point, then y+ must be zero in the same points. |
Display Modes | |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
[snappyHexMesh] non-smooth mesh | Svensson | OpenFOAM Meshing & Mesh Conversion | 11 | January 18, 2012 10:13 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
basic of mesh refinement | arya | CFX | 4 | June 19, 2007 13:21 |
