projection
Old   July 15, 2006, 11:22
Default projection
Ramesh
Hallo, Can anyone point me to an an approach as to how to find the coordinates of a projected point on a plane.
I have the following details, Corodinates of the 4 vertices of the plane and coordinate of the point to be projected
Ramesh
Old   July 16, 2006, 02:29
Default Re: projection
Alej
If I understood well what your problem is, you need to make a dot product to project. Define two orthogonal vectors on your plane (A and B) of norm 1 (divide by the norm), like an origin, then your point (P), will have PdotA in the direction of A, and PdotB in the direction of B
Old   July 16, 2006, 02:55
Ramesh
Could you please elaborate with some mathematical formulation. I just lost a bit of track in basic school mathematics. To repeat my problem. I have coordinates of 4 vertices A B C D of plane and point P in 3D space. I need to get the orthonormal projection of point P on plane that is coordinates of projected point PX on plane. One approach, if i am right is to define orthonormal vectors and take the dot product of it but it leads to a set of non linear equations to solve. so is there any other way
Old   July 16, 2006, 03:35
Alej
Ok, this is another approach, maybe more natural: Here the "old" reference system, is the general 3D system, where you have P expressed. The "new" system, is the plane PX. The vector OO`is a vector from the origin O of the old system to the O`new system.
First, where`s your PX plane? So you need to express your new coordinates in terms of the old`s ones. Thats made by projecting with sines and cosines. The angles should be known, because you choose how the new system is oriented. Suppose you have (all things with " ` " belongs to the new system): x`=ax y`=by z`=cz Now, that`s true for the unitary vectors x^`=ax^, y^`=by^, z^`=cz^
Now, you can express the point P as: P=OO`+P*, where P* is a vector from O`to P, but in the old coordinates (draw it and it will be clear)
You know P and OO`(you choose where the new system is), so make the rest, and get P*.
P* is Px* x^ + Py* y^ + Pz* z^, in terms of unitary vectors. Now, replace the unitary vectors in terms of x^`, y^`, z^` (unitary vectors of the new basis). Impose that the new coordinate z (that`s P`z, or Pz* z^`) is zero, because is a orthogonal projection.
Old   July 20, 2006, 08:59
Gerrit
The explanation by Alej is fully correct, but may result a bit fuzzy to you, because of the coordinate change.
First of all, a plane is defined by three points and not by four, even if D is taken in the same plane, with numerical errors the fourth point D will never be exactly in the same plane as given by ABC. So let's take only A, B and C.
Let every variable that starts with v be a vector taken of a point with respect to O and let O be your original eeehm origin, yep.
Take ve1=(vC-vA)/Length(vC-vA)
ve2=(vB-vA)/Length(vB-vA)
Now take vPnew=vP-vA
Next compute two dot products, notated as "*." dot1 and dot2, both scalar:
dot1=vPnew*.ve1 dot2=vPnew*.ve2
then
vPx=vA+dot1*ve1+dot2*ve2
I didn't check on errors, but this must work.
Projection Methods Petrov Main CFD Forum 2 June 10, 2011 09:50
Galerkin projection sara2115 Main CFD Forum 0 June 5, 2011 10:57
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
free surface flow and projection methods sylvain Main CFD Forum 2 April 26, 2002 09:45
A Second-Order Projection Method for Incompressibl Ivan Main CFD Forum 5 April 29, 2001 07:27
