Could not run a Fortran program
Old   July 21, 2006, 16:08
Default Could not run a Fortran program
Henry
Hello all,
I spent many days to finish the code of a fortran program. There is no error or warning when compiling every Subroutine. But there is a warning when I link them to build an "exe" file as the following:
"warning LNK4084: total image size -673341440 exceeds max (268435456); image may not run Creating browse info file..."
If I run the built "exe" file, there is a pop window coming out with the following error information:
"Could not execute: Bad executable format(Win32 error 193)."
Any suggestion please, thanks in advance.
Old   July 21, 2006, 17:04
Default Re: Could not run a Fortran program
Harish
Memory problem.What compiler do you use?There is an option to increase cache size in some compilers.Try making dynamic allocation with memory deletion if you are using f90 or f95.
-H
Old   July 22, 2006, 08:07
zonexo
maybe your matrix size is too big. that happen to me b4...
Old   July 22, 2006, 12:05
rt
Probably, it is due to large memory allocation. So if you assign large unusable memory you must decrease your dimension sizes and ... else if you need such large memory you must increase your RAM based on your allocation (note that your allowable memory allocation is equal to your RAM size + your assigned virtual memory, in win32 you can check it with alt+ctrl+del then performance tab and then check total memory)
Old   July 22, 2006, 14:37
Henry
Thanks Harish, I use Fortran Powerstation 4.0 and I couldnot find such option to increase the cache size.
Old   July 22, 2006, 14:41
Henry
I define many 3-d matrix around (100,100,20) and I will try to make it smaller to see what it will happen. thanks Zonexo.
Old   July 22, 2006, 15:01
Henry
Thanks a lot, rt. I will try to check it.
Old   July 22, 2006, 15:09
Renato.
You'll need to use a linker parameter (something like /image:[image size]). I can't remember but you'll find it checking on the linker error messages by the number of the error 4084.
This boring problem could be solved with memory allocated dynamically. In this case you'll get success on compiling/linking your program and the lack of memory would appear only at runtime with the use of swap (a kind of memory extension on your hard disk).
in order to use memory allocation you would do:
real*8, allocatable :: a(:,:, allocate(a(100,100,5)) ! body of your program deallocate (a)
Cheers
Renato.
Old   July 22, 2006, 19:55
ztdep
try to add anothter memory
Old   July 24, 2006, 08:44
Default Thanks, it can run now!
Henry
Thanks all,
It is the memory problem and I define the matrix smaller, then the program could run!
Execute a Fortran program with Fluent marye FLUENT 6 December 9, 2019 18:53
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
Fortran Program with FLUENT UDFs gautamcfd FLUENT 0 August 17, 2010 05:39
Fortran compiler for Transient run dinesh Siemens 1 January 10, 2009 07:06
Making program run faster Konstantinos Siemens 9 March 8, 2006 11:58
