Help regarding Steger Warming Scheme
Old   July 26, 2006, 19:07
Default Help regarding Steger Warming Scheme
Sunny
I implemented Steger Warming scheme (first order in space) for hypersonic Euler flow over cylinder. Results are little inaccurate on the surface of the cylinder.
It seems the problem is because of dissipative nature of this scheme.
Will making this scheme second order in space help reducing the dissipation problem ? Or is it better to change the scheme itself ?
Thanks in Advance, Sunny
Old   July 27, 2006, 02:17
Default Re: Help regarding Steger Warming Scheme
mar
If the solution appears "instable" you have to change the scheme. You can use a class of FVS (flux Vector spitting) scheme which can be easily implemented such as Van Leer, Hanel or AUSM; comparing different schemes you can find "your way"...
All these schemes can be coupled with a MUSCL approach to obtain second order schemes.
Old   July 27, 2006, 15:53
kapil
Making your scheme second order should definitely reduce the numerical dissipation in the solution. However you should be careful since less dissipation means solution can be unstable. To counter that problem I would go with mar's suggestion.
Also making the method second order can make your solution grid sensitive. You may need a good quality grid to have stable solution.
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
How to add steger warming flux vector splitting in open foam dushyant30 OpenFOAM 11 June 10, 2021 08:59
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
implicit steger warming fvs pooja Main CFD Forum 0 May 21, 2011 15:21
Implicit steger warming fvs pooja Main CFD Forum 3 May 19, 2011 06:48
