What CFD Program should I use?
Hello!
I am new to CFD and I need to model a slack moored heaving buoy with realistic waves in deep ocean. Basically all I need is a program that models something buoyant on the ocean that I can arbitrarily apply external forces to it. Could anyone be able to help me find a CFD program I could simulate this in? In my search I found that Star CCM+ could do it, but looking around on the web the costs seem forbiddingly expensive. This is for my masters and I dont have much to spend, and I really dont need all of the hundreds of other features that come with it. What other alternatives are there out there? Thank you so much in advance. |
Hi, I think Ansys Aqwa is meant for mooring calculations, wave modelling and offshore stuff in general. Maybe you can contact your local Ansys supplier for detailed information.
Cheers, Michujo. EDIT: Ansys licenses are expensive though... |
my name is Mihael and will be visiting this forum more often as I am writing my bacc. thessis. I have data sets in txt containing time series and mean values of wind velocitity in a wind tunnel. I would like to plot the results (contour plots for example). Can you suggest me the programs that would be good for such an application. Thank you. Mihael |
Mihael,I think that you can do what you want with only gnuplot, but if you have the time check ParaView. It is a powerful program to look on cfd results or so. For the late one you will maybe need to change the input file that you have, in a different format like, " .csv " maybe. frownless, it is maybe a silly suggestion of mine but I think that you should contact CD-adapco, i.e. StarCCM+. Maybe they are able to give you a license for only a small amount of time, reducing this way the cost. You never know. Thanks, rick |
You make look into using OpenFOAM for this. There is a bit of a steep learning curve at the beginning, but it is a very powerful program. Best of all, it is free to use.
Thanks guys, I will check out this OpenFOAM, sounds like a good idea!
Mihael, you should be able to do that with literally any plotting tool or code. If you have access to Mathematica I would recommend it because what it lacks in efficiency it makes up for in slick looking plots. Otherwise matlab or python can do a pretty good contour. |
