About Young-laplacian equation.
Like Tree2Likes
  • 1 Post By michujo
  • 1 Post By michujo
Old   June 13, 2013, 20:30
Default About Young-laplacian equation.
Dongyue Li
sharonyue is on a distinguished road
Hi guys,
In physics, the Young–Laplace equation is a nonlinear partial differential equation that describes the capillary pressure difference sustained across the interface between two static fluids, such as water and air, due to the phenomenon of surface tension. But how can I deduce this equation?http://en.wikipedia.org/wiki/Young%E...place_equation
\Delta p=- \gamma \nabla n
\kappa = - \nabla \cdot \left(\frac{\nabla \alpha}{|\nabla \alpha |}\right)
sharonyue is offline   Reply With Quote
Old   June 14, 2013, 03:54
michujo is on a distinguished road
Hi, just take a differential shell element (which represents the interface between both fluids) with different radius of curvature on each side (R1 and R2). The length of the element sides are dx1 and dx2, which span a differential angle d\theta_1 and d\theta_2 (where dx_1=R_1\cdot d\theta_1 and dx_2=R_2\cdot d\theta_2).
Consider static equilibrium of the shell element and you get something like this:
\Delta p=\gamma \cdot \left[ 2\cdot dx_2 \cdot sin( d\theta_1 /2)+2\cdot dx_1 \cdot sin( d\theta_2 /2) \right]
Assume small angles (sin(theta) approx. theta) and you get this:
\Delta p=\gamma \cdot \left( 1/R_1+1/R_2\right )
The expression comes from assuming that the pressure difference (which pushes the shell upwards normally to its surface, considering the higher pressure on the concave side of the shell) balances the forces due to surface tension, which pull the shell downwards at angles d\theta_1 /2 and d\theta_2 /2.
The easiest way is to draw the shell element with the dimensions and the force vectors and deducing the equilibrium equation.
Cheers,
Michujo.
michujo is offline   Reply With Quote
Old   June 14, 2013, 04:53
Dongyue Li
Cheers,
Michujo.
Hi Michujo,
Thanks alot, after draw the shell element, I know \Delta p=\gamma \cdot \left( 1/R_1+1/R_2\right ), but how can I turn it to \Delta p=\gamma \cdot \nabla n?
Now I only know n=\nabla \alpha
Could it be said that \left( 1/R_1+1/R_2\right ) =- \nabla n?
Old   June 14, 2013, 07:53
Hi, follow the variation of the normal vector along the element. Imagine that, at the center of the shell element, the normal is point upwards but, if you move along one side in the, let's say, the x direction, the normal at the edge of the element will be crooked because of the curvature of the element.
At the edge the normal will not be pointing exactly upwards but somewhat along the x direction. How much is "somewhat"? => sin(d\theta_1/2) \approx d\theta_1/2. The variation in the x coordinate is dx/2 (half length of the element along the x coordinate).
Therefore the variation of the x component of the normal vector as we move along the x coordinate is: n_{x_1}|_{x_1+dx_1/2}-n_{x_1}|_{x_1}=\frac{\partial n_{x_1}}{\partial x_1}\cdot dx_1/2=d\theta_1/2 and re-arranging: \frac{\partial n_{x_1}}{\partial x_1}=d\theta_1/dx_1=1/R_1
Thus \nabla \cdot n= \frac{\partial n_{x_1}}{\partial x_1}+\frac{\partial n_{x_2}}{\partial x_2}=1/R_1+1/R_2 expresses the variation of the normal components due to curvature of the fluids interface.
It's just some geometry and some algebraic manipulations.
Cheers,
Michujo.
sharonyue likes this.
Old   June 14, 2013, 08:26
Dongyue Li
At the edge the normal will not be pointing exactly upwards but somewhat along the x direction. How much is "somewhat"? => sin(\theta_1/2) \approx \theta_1/2. The variation in the x coordinate is dx/2 (half length of the element along the x coordinate).
Therefore the variation of the x component of the normal vector as we move along the x coordinate is: n_{x_1}|_{x_1+dx_1/2}-n_{x_1}|_{x_1}=\frac{\partial n_{x_1}}{\partial x_1}\cdot dx_1/2=\theta_1/2 and re-arranging: \frac{\partial n_{x_1}}{\partial x_1}=d\theta_1/dx_1=1/R_1
Cheers,
Michujo.
I just came back. Thats beautiful!! I need time to see it deeply, Thanks very much Michujo!!!
Old   June 14, 2013, 08:53
No worries. I drew it so it's much easier to see instead of talking about vectors and differentials...
Cheers,
Michujo.
Old   June 14, 2013, 09:47
Dongyue Li
At the edge the normal will not be pointing exactly upwards but somewhat along the x direction. How much is "somewhat"? => .
Hi Michujo,
I just think about it deeply, Thats more clear now. Thats very kool. But there is only one thing left now: I dont understand why the increment in x-component of the normal vector equals sin d theta/2, could you explain it for a little bit? Thanks for your patience!!Or you can recommend me some papers about this.
In this image, q's magnitude equals dtheta/2?
Old   June 15, 2013, 10:53
Hi, yes, in the image the magnitude of q is d\theta/2.
It's all geometry:
1) The interface element spans d\theta_1/2 and d\theta_2/2 along the x1 and x2 coordinates.
2) Also, you know that the modulus of the normal vector is 1.
3) Finally, as the normal vector is always perpendicular to the interface, by geometry, as the element turns and angle of d\theta/2 so will the normal vector. Therefore the components of the normal vector will be n_{x1}=1\cdot sin(d\theta_1/2) and n_{z}=1\cdot cos(d\theta_2/2). For that you have moved a distance dx1/2 from the center of the element.
4) sin(\theta) tends to \theta as \theta tends to zero.
I cannot think of any reference now but I'm sure there must be tons of information out there somewhere.
Cheers,
Michujo.
Old   June 15, 2013, 19:26
Dongyue Li
It's all geometry:
Cheers,
Michujo.
Woo, I figure this out totally.! Thanks buddy.!
Cheers!
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Laplacian operator and nuSgs for heat equation Bedotto OpenFOAM Programming & Development 4 September 7, 2009 15:08
