June 18, 2013, 17:39 |
difference between turbulence model
rayan
Rep Power: 12 |
Hi everyone,
I'am a new user of CFD softeware (fluent) so I want to know what's the difference between the model of turbulence LES, DES, and RANS and what's the advantages and the disadvantage of each one of them, which of them is linking to mech, etc. Thanks for your help and welcom for all explications THanks |
June 18, 2013, 19:24 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
I think that the first issue is to understand that LES, RANS, ecc, are different "formulations", not models... That means that you solve for different types of variables. I suggest to start with a reading of a good CFD book before to get into turbulence modelling...then, the Pope's book can be useful |
June 19, 2013, 05:57 |
#3 | |
rayan
Rep Power: 12 |
Thank you for your answer !
I want to know in what context can be used LES or RANS At the same time I research a book Thanks Quote:
June 19, 2013, 14:58 |
Alberto Modrego
Rep Power: 12 |
Hello;
If you go, if you go to the tab help in fluent > PDF's> User's Guide and go to the chapter 13, you will see whtas the best turbulence model and what are the main characteristics of each model easily. I am in the same problem than you and i am using this information. |
June 19, 2013, 15:27 |
#5 | |
rayan
Rep Power: 12 |
Thank u a lot amodrego
Display Modes | |
Turbulence Model in Finite Difference | nw_ds | Main CFD Forum | 0 | June 3, 2012 14:26 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
v2-f turbulence model in CFX? | flga | CFX | 14 | November 23, 2006 06:12 |
