June 21, 2013, 12:02 |
No-slip B.C.
Jing
Rep Power: 14 |
Dear All
Hello I have simulated a simple channel with LBM. At the bottom of the channel, I applied the No-Slip B.C., i.e. bounce-back. As far as I know, at this boundary, the velocity is zero. But the vectors show that it is NOT. How do you explain this? Thanks |
June 25, 2013, 11:07 |
Wouter
What do you mean with "bounce-back"? It does not sound like a no-slip boundary condition (which would set the velocity of the fluid to the velocity of the wall). So either your wall is moving or you are not applying your boundary condition (all components of the velocity vector to zero) correctly.
June 26, 2013, 04:54 |
Rep Power: 15 |
Hi.
Is your code cell centered or vertex centered? If the velocities you are plotting correspond to those at the center of the first row of cells above the wall then they do not need to be zero, velocities are only zero at the wall (at the bottom boundary of those cells). Did you check if your velocity field is divergence-free? Cheers, Michujo. |
Display Modes | |
2-d axisymmetric microtube flow with velocity slip and temperature jump b.c. | dayashankar | FLUENT | 1 | May 18, 2016 21:45 |
inviscid wall and slip wall b.c. | Shenren_CN | Main CFD Forum | 0 | September 21, 2011 11:57 |
slip velocity B.C | sajad_abasi | CFX | 0 | September 20, 2011 05:45 |
Confusion between 'non-slip' and 'slip' B.C | jinwon park | Main CFD Forum | 7 | March 6, 2008 04:56 |
slip B.C | mohsen | Main CFD Forum | 3 | January 29, 2003 19:54 |
