BC for Self-contained Chamber
Old   August 10, 2006, 23:40
Default BC for Self-contained Chamber
Amod
I am trying to simulate the flow condition inside a Base Transceiver Station, an outdoor shelter used by telecommunication industry.
The computational domain consists of a shelter having fans inside it to circulate the air. Their is no physical inlet or outlet. For my CFD simulation, I can replace fan with the inlet. What do I need to do for the outlet boundary condition?
Thanks
Old   August 11, 2006, 09:26
Default Re: BC for Self-contained Chamber
Mani
A regular inlet condition alone won't do it for the fan. The fan introduces momentum and energy to your system, but mass has to be conserved. You might think of a combination of inlet and outlet conditions for each fan, i.e. model the fan as "black box" with specified inlet and outlet conditions.
Old   August 11, 2006, 13:12
Jim_Park
Or treat it as source term of momentum in the region that the fan occupies.
This is tricky as the fan is likely to add angular momentum as well as axial momentum to the fluid. These 'suggest' a cylindrical coordinate system. If your 'chamber' isn't a cylinder that's coaxial with the fan rotation axis, you'll need to be careful in assigning the momentum creation correctly in the coordinate system you're using.
Good luck.
Old   August 12, 2006, 06:09
Amod Kumar
Mani/Jim,
Thanks for your inputs. My computational domain is almost cubical with various electronic heat sources and PCM heat sinks here and there. The fan is mounted on the ceiling vertically downwards. So, I can put the momentum source at the fan (blade) location.
But I do not know how to do in CFX. Any further help would be highly appreciated.
Amod
Old   August 12, 2006, 09:33
Jim_Park
I haven't tried to use CFX in 9 or 10 years, so can't help with that. I think there's a CRX user forum here on cfd-online. You might try that.
Airflow in a chamber Issa CFX 9 January 30, 2010 16:10
I need design planes of combustion chamber HITACHI GE AdidaKK Main CFD Forum 0 July 2, 2009 14:04
Coal particles in combustion chamber Luis Filipe Fabiani CFX 2 March 10, 2009 15:37
Flow and Heat transfer in a Thawing chamber B.Prabhu FLUENT 0 May 12, 2002 15:13
A moving object within a chamber Whitaker FLUENT 5 October 10, 2000 22:02
