reversed flow
Old   July 2, 2013, 09:08
rayan
rayan24 is on a distinguished road
outflow its OK!
Originally Posted by steven1 View Post
so what should I put as the gauge pressure?
rayan24 is offline   Reply With Quote
Old   July 2, 2013, 09:39
steven
steven1 is on a distinguished road
Originally Posted by rayan24 View Post
outflow its OK!
OK, I have tried a lot the outflow, but i always get reversed flow and also the problem of convergence. how did you solve your problem?
steven1 is offline   Reply With Quote
Old   July 2, 2013, 10:00
rayan
I decreased at least the different under-relaxation factor (0.1 and 0.2) because in the beginning of simulation we have very significant disruption to overcome so you should lower these values, then when the solution begins to stabilize you can increase it gradually
Old   July 2, 2013, 11:33
steven
OK, I will have a try. Thank you.
Old   July 3, 2013, 01:33
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Steven,
Is your problem fixed?
Don't focus on reversed flow warning.
The convergence is the one you need to fix.
Maybe you should consider & switch on unsteady solver, if rayan's tipp didn't help you.
Did you also try to compute on a much finer grid?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 3, 2013, 08:21
steven
Originally Posted by -mAx- View Post
Steven,
Thank you Max.
I have solved the problem of convergence. Do you remember the gambit file that i sent to you. I united the two volumes in the center, then it worked without warning under the model 'outflow'. This makes me confused, I don't know why this works. Do you know what happened?
Old   July 3, 2013, 08:56
-mAx-'s Avatar
Maxime Perelli
Good to read you solved your problem.
But sounds weird.
Anyway it is solved (maybe an internal surface or whatever, but I checked and everything was ok)
Old   July 3, 2013, 09:30
steven
But sounds weird.
You are right, it is a problem of interface. I came to know why just now. My professor told me that i overlapped two faces together at the entrance of the small tube. When i united them together, i removed the face which caused problem.
Anyway, Thank you so much.
Old   July 3, 2013, 09:53
-mAx-'s Avatar
Maxime Perelli
yes, typical error in Gambit
Old   July 5, 2013, 07:09
steven
Hello Max,
I have a question, how can i creat a face to mesure the pressure of my larger tube depending on the lenghth?
Thank you.
Steven
Old   July 5, 2013, 07:19
-mAx-'s Avatar
Maxime Perelli
you can do that in fluent, post-processor.
I cannot remember the exact name, I can tell you on Monday when I return at the office.
Kids are giving more troubles than mesh....
Old   July 5, 2013, 07:24
michujo is on a distinguished road
Hi, I'd go to Insert/Location/Plane in CFD-Post. Then define the plane (e.g., z=constant) and plot the desired variable on it.
Cheers,
Michujo.
michujo is offline   Reply With Quote
Old   July 5, 2013, 07:36
steven
Haha, maybe you were more naughty as a kid
Old   July 5, 2013, 07:38
steven
Cheers,
Michujo.
OK, thank you, i will have a try.
Steven.
Thread Tools
Trackbacks are On
Significant Reversed Flow at Outflow Problems [ANSYS FLUENT] NormalVector ANSYS 1 May 15, 2012 23:50
Reversed Flow for a tenth slice of a rotor neptunemmx FLUENT 10 January 30, 2012 14:51
Reversed flow...>>>Please HELP...! sushii FLUENT 14 October 29, 2007 05:27
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
reversed flow Sastry FLUENT 5 March 22, 2007 09:05
