Solution changing with dt.
Old   July 1, 2013, 08:57
Default Solution changing with dt.
qrie is on a distinguished road
I have a code in cylindrical coordinates that uses central differences. My problem is this: when I change the time step size, keeping everything else the same(grid included), I get vastly differing solutions.
Been breaking my head over this - any ideas??
Thanks in advance!
qrie is offline   Reply With Quote
Old   July 1, 2013, 11:21
cfdnewbie
cfdnewbie is on a distinguished road
Are you talking about a steasy state problem or an unsteady one?
cfdnewbie is offline   Reply With Quote
Old   July 2, 2013, 01:01
Its a steady state problem.
Old   July 2, 2013, 03:18
cfdnewbie
Are you using an implicit or explicit solver for this?
Old   July 2, 2013, 04:25
Advection terms are explicitly calculated. Viscous terms in the radial direction alone are implicitly calculated.
Old   July 2, 2013, 05:09
Filippo Maria Denaro
FMDenaro will become famous soon enoughFMDenaro will become famous soon enough
I think that the discussion of your problem must be better focused:
- what variable you see that strongly change with dt?
- what about the cell Re number? are you sure to fulfill the stability constraint?
- have you experienced the same behavior for refined h steps?
FMDenaro is offline   Reply With Quote
dt size
Thread Tools
Trackbacks are On
Integrated conjugate heat transfer solver in OpenFOAM hjasak OpenFOAM Running, Solving & CFD 170 March 2, 2016 05:20
Asymmetrical solution using RANS Marli FLUENT 2 January 9, 2015 10:26
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Mesh independent solution CFX Begineer CFX 0 October 27, 2002 11:54
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
