Particle trace velocity structure in grid fire simulation
Old   July 12, 2013, 04:25
Default Particle trace velocity structure in grid fire simulation
Hank Lord Chang
hanklord is on a distinguished road
Hi ,
I'm developing a method for fire animation design based on fire simulation (solved by Navier Stokes Equation).
First, I add some trace particles which flow along the velocity field in the simulation and particles will catch the simulation data (temperature and velocity), each particle will form a pathline. (similar to this paper at section 4.2, http://vis.cs.ucdavis.edu/papers/SCA2011.pdf)
After the data sampling, I will compute the data similarity between these path lines.
Later, I will synthesis the new simulation data use these similarity data.(i.e. The similar path lines will be put nearby)
But, this synthesis method by the similarity data seems can't maintain the velocity structure (ex. vorticity) even consider the data similarities.
Is there any possible solution or keywords to handle this? (I'm trying to read the other articles to find solutions)
Thank.
hanklord is offline   Reply With Quote
Fire simulation mesumon203 FLUENT 7 July 4, 2012 07:40
AVL fire Exhaust manifold Simulation mohsenfjs Main CFD Forum 0 May 15, 2010 12:51
How to approach calculating a stream function given a velocity profile on a grid ComFlu Main CFD Forum 1 October 25, 2009 14:25
Temperature errors on fire simulation? raymond Siemens 0 January 10, 2002 21:32
Dual grid structure - enlightment ?? Jens Main CFD Forum 2 August 1, 2000 19:01
