closed casing with fan and water
Old   August 27, 1999, 01:16
Default closed casing with fan and water
Tom
Hy, I try to simulate water in a cylindrical casing (free surface, diameter 1m, high about 0.2m) and a propeller with a diameter of 0.05m in the water. The sense of that is to bring the water into rotation with a given speed v-tan at special points. The propeller is modelled as a fan with no circumferential and radial velocity-component. I use tets, k-eps. Now the circumferential-velocity of the water in the casing is at all points of the simulation as double as high as the measured one (0.3m/s). yplus at the side walls and the bottom is ok, the surface on the top is symmetrie (no shear-stress..). What can I do ? Thank you very much
Internal fan - energy used pk FLUENT 0 April 22, 2008 07:01
Help: IC engine fan design Sigan Main CFD Forum 1 May 24, 2005 18:40
Separation phenomenon of water, droplet and air Raymond CFX 0 July 9, 2004 22:59
