Method of characterestics (MOC)
Old   July 4, 2013, 11:56
Default Method of characterestics (MOC)
CFDLearner
Farouk is on a distinguished road
Hi, I am currently trying to understand the position and state diagrams used in the Method Of Characteristics (used to solve PDE for CFD)...I can't find much useful literature about the topic..so if any one has suggestions, that would be of great help.
Thanks in advance.
Farouk is offline   Reply With Quote
Old   July 4, 2013, 12:34
Filippo Maria Denaro
FMDenaro will become famous soon enoughFMDenaro will become famous soon enough
Originally Posted by Farouk View Post
Hi, I am curently trying to understand the position and state diagrams used in the Method Of Characterestics (used to solve PDE for CFD)...I can't find much usefull literature about the topic..so if any one has suggestions, that would be of great help.
Thanks in advance.
see the classical book of Zucrow
FMDenaro is offline   Reply With Quote
Old   July 7, 2013, 12:25
CFDLearner
Hi FMDenaro and thanks for the reply.
The text you suggested was very helpful, but still, it didn't answer all my questions, mainly, the use of left going \lambda and right going \betacharacteristics.
For those who are interested, you can see below the two diagrams for a simple wave.
Does anyone happen to have a practical explanation?
Thanks
Old   July 7, 2013, 12:38
have a look to the simple wave analysis, homoentropic flows have two Riemann invariants, one along each characteristic curve that allow you to get an exact solution. Generally, the application is reported as a piston moving in a tube without dissipation. The book of Zucrow illustrated such case. Furthermore, the more modern book of LeVeque can be also useful
Old   July 8, 2013, 16:57
Jonny
Jonny6001 is on a distinguished road
Hello.
Generally speaking the method of characteristics is used to change a PDE to an ODE. It does this by making one of the variables a function of the other variable.
I like to think of the method by considering a second coordinate system that moves along the second variable. It's position along the second variable is a function of the first variable. Then say that the derivative of the function with respect to the new coordinate system is 0. Therefore the characteristic must stay constant along the curves.
This is a very simplified analogy but here goes!
On the 'x-t' diagram with t=0 each characteristic curve has a value. The gradient of the curves emerging from the t=0 represents the speed of information propagation. Think of it as several cars starting from different positions at the same time. If all cars move parallel to each other (have the same velocity) they will never hit each other. However if the car behind moves quicker (has a different gradient to the characteristic curve) it will eventually hit the car in front. This is the point of a shockwave.
The method can be used for the exact solution of equations such as linear advection. A non-linear equation (Burgers) results in curved characteristic curves.
Hope that's not confused you further.
Jonny6001 is offline   Reply With Quote
Old   July 9, 2013, 03:16
CFDLearner
Originally Posted by Jonny6001 View Post
Hello.
Hi Jonny6001 and thanks for the answer. That's exactly the type of answers I was looking for (no mathematics, but logic)...I will try to work some theory and examples, hopefully, I will manage to implement something simple, and i will post back to this thread.
Cheers.
Old   July 9, 2013, 09:16
CFDLearner
Hi there, does any one happen to have an implemented MOC code? possibly in Matlab? That would be a good start for me.
Regards
Old   January 15, 2015, 17:23
yang Shao
Yashao is on a distinguished road
I'm studying the 3d MOC in reacting flow recently, I read several papers and books and now I understand the characteristic surfaces, and I can get the the compatibility equation, but the following numerical part really makes me headache. How to solve the compatibility equation in finite difference is very hard for me.
I'd appreciate it if anyone can give me some suggestion!
Yashao is offline   Reply With Quote
Thread Tools
Trackbacks are On
discretizer - gmshToFoam Andyjoe Open Source Meshers: Gmsh, Netgen, CGNS, ... 13 March 14, 2012 05:35
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 10:55
Comparison: Finite Volume Method vs. Analytic Method m-fry Main CFD Forum 1 April 20, 2010 14:40
Code for most powerfull FDV Method D.S.Nasan Main CFD Forum 6 September 4, 2008 02:08
Help about the preconditioner in gmres method Dan Gao Main CFD Forum 3 July 5, 2008 01:18
