Missile Datcom
Old   July 11, 2013, 04:17
Default Missile Datcom
Bryan
Missileman is on a distinguished road
Not quite sure if this is the right place to ask this, but I'll go with it anyway.
I'm trying out this sample input file from this website (http://www.phoenix-int.com/~Analysis...r/example.html), but I couldn't get the same output as shown. Below are my input and output files:
INPUT FILE:
CASEID HYPMIS
* Use newtonian imact theory.
HYPER
* Dimensions are in inches
DIM IN
$FLTCON NMACH=1.0,MACH=1.0,ALT=0.0,NALPHA=2.0,ALPHA(1)=10. 0,0.0,BETA=0.0,$
$REFQ XCG=81.0,LREF=21.0,SREF =346.4,SCALE=1.0,ROUGH=2.5E-4,BLAYER=TURB,$
* BODY
$AXIBOD TAFT=0.0,LAFT=20.0,DAFT=20.0,DEXIT=16.0,TNOSE=CONE ,LNOSE=20.0,$
$AXIBOD DNOSE=20.0,LCENTR=140.0,DCENTR=20.0,$
* TAILS WITH FOUR PANELS
$FINSET1 SECTYP=ARC,ZUPPER=0.04,LMAXU=0.4,0.4,LFLATU=0.0,0. 0,SSPAN=10.0,15.0,$
$FINSET1 CHORD=20.0,10.8,SWEEP=30.0,XLE=0.0,STA=0.0,NPANEL= 4.0,$
$FINSET1 PHIF=45.0,135.0,225.0,315.0,$
$TRIM SET=1.0,PANL1=.TRUE.,PANL2=.TRUE.,PANL3=.TRUE.,PAN L4=.TRUE.,$
PART
SAVE
NEXT CASE
OUTPUT FILE:
1 ***** THE USAF AUTOMATED MISSILE DATCOM * REV 3/99 *****
AERODYNAMIC METHODS FOR MISSILE CONFIGURATIONS
CONERR - INPUT ERROR CHECKING
ERROR CODES - N* DENOTES THE NUMBER OF OCCURENCES OF EACH ERROR
A - UNKNOWN VARIABLE NAME
B - MISSING EQUAL SIGN FOLLOWING VARIABLE NAME
C - NON-ARRAY VARIABLE HAS AN ARRAY ELEMENTDESIGNATION - (N)
D - NON-ARRAY VARIABLE HAS MULTIPLE VALUES ASSIGNED
E - ASSIGNED VALUES EXCEED ARRAY DIMENSION
F - SYNTAX ERROR
************************* INPUT DATA CARDS *************************
1 *------------------------------------------------------------------------
2 CASEID HYPMIS
3 * Use newtonian imact theory.
4 HYPER
5 * Dimensions are in inches
6 DIM IN
7 *
8 *----------------------------------------------------------------------------
9 *
10 $FLTCON NMACH=1.0,MACH=1.0,ALT=0.0,NALPHA=2.0,ALPHA(1)=10. 0,0.0,BETA=0.0,$
11 *
12 *----------------------------------------------------------------------------
13 *
14 $REFQ XCG=81.0,LREF=21.0,SREF =346.4,SCALE=1.0,ROUGH=2.5E-4,BLAYER=TURB,$
** SUBSTITUTING NUMERIC FOR NAME TURB
15 *
16 *----------------------------------------------------------------------------
17 *
18 * BODY
19 $AXIBOD TAFT=0.0,LAFT=20.0,DAFT=20.0,DEXIT=16.0,TNOSE=CONE ,LNOSE=20.0,$
** SUBSTITUTING NUMERIC FOR NAME CONE
20 $AXIBOD DNOSE=20.0,LCENTR=140.0,DCENTR=20.0,$
21 *
22 *----------------------------------------------------------------------------
23 *
24 * TAILS WITH FOUR PANELS
25 $FINSET1 SECTYP=ARC,ZUPPER=0.04,LMAXU=0.4,0.4,LFLATU=0.0,0. 0,SSPAN=10.0,15.0,$
** SUBSTITUTING NUMERIC FOR NAME ARC
26 $FINSET1 CHORD=20.0,10.8,SWEEP=30.0,XLE=0.0,STA=0.0,NPANEL= 4.0,$
27 $FINSET1 PHIF=45.0,135.0,225.0,315.0,$
28 $TRIM SET=1.0,PANL1=.TRUE.,PANL2=.TRUE.,PANL3=.TRUE.,PAN L4=.TRUE.,$
29 PART
30 SAVE
NEXT CASE ** MISSING NEXT CASE CARD ADDED **
1 ***** THE USAF AUTOMATED MISSILE DATCOM * REV 3/99 ***** CASE 1
AERODYNAMIC METHODS FOR MISSILE CONFIGURATIONS PAGE 1
CASE INPUTS
FOLLOWING ARE THE CARDS INPUT FOR THIS CASE
CASEID HYPMIS
HYPER
DIM IN
$REFQ XCG=81.0,LREF=21.0,SREF =346.4,SCALE=1.0,ROUGH=2.5E-4,BLAYER=0.,$
* BODY
$AXIBOD TAFT=0.0,LAFT=20.0,DAFT=20.0,DEXIT=16.0,TNOSE=0.,L NOSE=20.0,$
$FINSET1 SECTYP=2.,ZUPPER=0.04,LMAXU=0.4,0.4,LFLATU=0.0,0.0 ,SSPAN=10.0,15.0,$
PART
SAVE
NEXT CASE
*** END OF JOB ***
Missileman is offline   Reply With Quote
Thread Tools
Trackbacks are On
Generating Mesh for Body-Tail missile configuration using OF mecbe2002 OpenFOAM 0 April 19, 2010 06:14
DATCOM for AUV -- help needed bhagat Main CFD Forum 0 February 15, 2010 09:17
Missile Datcom STAR Main CFD Forum 1 August 16, 2005 12:58
GRID MESHING AROUND A MISSILE Chris FLUENT 6 April 8, 2005 14:18
