July 11, 2013, 07:15 |
Flapping wing aerodynamics
Rep Power: 13 |
I'm doing my thesis on plain flapped NACA 0012 airfoil. I ran some simulations where flap angle was varied from 10-50 degrees. But when I plot the curve of Cd Vs mach number, for 40 and 50 degrees of flap angle maximum Cd occurs at Mach 0.5 instead of Mach 1. And with increasing mach number Cd decreases afterwards . But, for 10, 20 and 30 degrees of flap angle it conforms to the standard curve somewhat. Way is this happening?? If this is the real case, can anyone explain the physical mechanism occurring there??
July 12, 2013, 08:19 |
Lefteris
Rep Power: 15 |
Can you give more information please?
I don't know which equations you're solving or the freestream conditions but I think that at some point the local Mach number exceeds the local speed of sound and you have a shock wave.
Lefteris |
July 12, 2013, 11:30 |
#3 | |
Rep Power: 13 |
I'm doing my simulation in ansys fluent. Used k-omega SST model. Mach no was varied from 0.1 to 1.0 for each flap angles (i.e. 10, 20, 30, 40, 50). I also tried these simulations on Slidworks flow simulation. But at higher flap angles (30, 40, 50) solution does not even converge (Fluent also). I took the avg. of highest and lowest values for computing Cl and Cd. I used conventional equations of Cl and Cd. Temp: 300k, rho: 1.225, viscosity: 1.749E-5 Anything wrong with the flap angles?? In internet I could not find any results for such high AoA. I would be very nice if you help me to understand this phenomenon. Any academic reading material will also do. Thank you for your reply. |
July 12, 2013, 12:03 |
Lefteris
Rep Power: 15 |
For M>0.3 the assumption that the flow is incompressible does not hold. The flow must be considered compressible. Did you account for compressibility in your calculations?
Lefteris |
July 13, 2013, 15:11 |
Rep Power: 13 |
oh... Actually I did not assume compressible flow for Mach no.>0.3. Should I select density based solver in Fluent for Mach > 0.3? What should I do for simulating compressible flow in SolidWorks Flow simulatuion??
Thank you. |
DEFINE_CG_MOTION for flapping wing UDF | xyzch001 | Fluent UDF and Scheme Programming | 21 | February 7, 2022 07:47 |
CFD of flapping wing mav | sultan | Main CFD Forum | 12 | February 28, 2013 19:01 |
[Other] Is my setup correct?I am trying to simulate flapping motion of the wing using Dynamic | cfd seeker | ANSYS Meshing & Geometry | 2 | September 13, 2012 06:02 |
Lift and drag coefficients of a flapping wing aircraft | Julian121 | FLUENT | 36 | August 24, 2012 19:37 |
3D wing (flapping elastically) flexing UDF problem | djan | Fluent UDF and Scheme Programming | 3 | March 30, 2012 11:37 |
