turbulent viscosity error
Old   July 11, 2013, 09:29
Unhappy turbulent viscosity error
krishna
zore is on a distinguished road
turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 23717 cells
what does this mean..... and how to over come this problem???
can any put some light on this...
thanks
zore is offline   Reply With Quote
Old   July 12, 2013, 00:01
Mitesh Vegad
m.vegad is on a distinguished road
AM not sure about this....but this may work....
There is something called CEILING and FLOOR values set in Fluent..
Its there in the one of the menus ... may be SET sub menu or something.
Change the value of ceiling ....
m.vegad is offline   Reply With Quote
Old   July 12, 2013, 05:26
krishna
Thanks vegad...
I searched for CEILING and FLOOR values set in Fluent, but I could not find them..
There is limits option in fluent under solve--control, where we can actually change this limit values... However, solution obtained by changing this values are not accepted.
I want to know the reason behind this error.... turbulent viscosity limited to viscosity ratio of 1.000000e+005 in 23717 cells, this error arise because of mesh quality or some thing else...
Old   July 12, 2013, 06:25
flotus1's Avatar
Alex
flotus1 will become famous soon enoughflotus1 will become famous soon enough
Did you do a forum search? There is a ton of similar threads
http://www.cfd-online.com/Forums/sea...archid=1809929
flotus1 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Problem with divergence TDK FLUENT 11 July 31, 2016 06:03
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
